TCBear
Oct 15, 2023Explorer II
"...5 pages of trying to help."
Bingo.
Off on a tangent, the issue of determining if a wastewater vent is...well, venting. If there's a removable rooftop rain cap over a vent, then you could likely drop down a piece of sprinkler pipe or other pokin' stick to check for an obstruction. But if the cap is permanently fixed, perhaps you could tie a large nut (as in nut and bolt) or similar to a heavy string and feed it down the vent pipe, see what that reveals. Or run an electrical extension cord past the cap, something substantial yet flexible. I wonder if anyone has ever ran water from a garden hose down a roof vent or if that's even a good idea since it's an air vent rather than a water pipe.
As for the 300 model toilet, based on prior posts...
-Research the 300 further online.
-Replace the seals (may not permanently resolve).
-Replace toilet.
-Keep toilet in place but attempt to seep full-strength, non-bleach antibacterial cleaner past the seals to kill off odor in the accumulated liquid goo (kill the bacteria = kill the odor).
-Dump several pails (at least 5 gal) of water down the toilet at the start of each trip to dilute subsequent blackwater contents, but not so much as to impact tank capacity.
-Spritz the entire toilet bowl with any household spray cleaner after each use, or a few times each day, a supplemental detergent "flush."
-Spray an antibacterial cleaner along the bottom of fixtures near the toilet (walls, bathtub, cabinets) so that it seeps under the fixtures and contacts anything yellow that could have gotten down there. (If you KNEW that was a problem, an enzyme pet urine spray may be a better choice.)
-Try a different blackwater chemical treatment if necessary.
Bingo.
-Replace toilet.
