opnspaces
Jul 24, 2013Navigator III
As everyone has said, you or to be exact your pump will be fine. Put some water in the fresh tank, open a faucet and turn on the pump switch. The reason the pump did not run when you were hooked up is that the water pressure did not drop to the point that the pump would turn on.
44,066 PostsLatest Activity: Jul 25, 2018
