westend
Sep 27, 2015Explorer
LaunchnRetrieve wrote:After you have the three mounting bolts out, you should be able to pull the jack tube up and out of the hole on the tongue unless you bent it almost at a 90.
I guess there's going to be one more step than the 3 bolts. I will have to cut the jack in order to pull it out since it's bent.
Too much arthritis to use a hack saw. What power tool should I buy to cut that tube?
Any input on weight rating?
44,071 PostsLatest Activity: Aug 23, 2026
