bikendan
Jun 05, 2016Explorer
Saint Augustine wrote:bikendan wrote:Saint Augustine wrote:
I'm going with brochure rate and adding a a couple of hundred pounds for loading. I'm looking at the 21 ft. Line that Forest River has. The line with the slides. Just beginning my search. Thanks for responses so far.
You still haven't told us which spec is the 4200 number.
Is it the fictional brochure/website dry weight or the GVWR number?
And what is the dry hitch weight? That's the number that most SUVs will have issues with.
Base/dry unit weight of rock wood mini lite 2109s, a unit we are looking at is 4091.
well then, my Rockwood had the same brochure/website Base/dry weight.
when it arrived from the factory, its actual weight was 4471lbs.
loaded for camping, for two of us, it is a minimum of 5000lbs.
so figure you'll need a v-8 SUV.
