You should look at the gross vehicle combination weight rating (GVCWR) on your suburban's door post to make sure what you can safely tow that heavy. Need to figure TV loaded weight with passengers, belongings and full tank of gas. Once you the know what that is; deduct that weight from the GVCWR. Then you know what you can safely tow. Exceeding the manufactures weight ratings could effect your insurance coverage. also the actual weight on the camper is greatly effected by what you load into it, food, belongings, water, propane.
