pk54's avatar
pk54
suburban as a tv for first tme
We have 28 ft Keystone Outback, GVWR 7,000 lb that we have always pulled with our 1/2 Ton pickup. The pickup is set up for pulling with airbag assist suspension and a 6.2 engine and it does a great job. We need extra space to take our 4 grandkids on a trip so we are looking at using a 2011 suburban with a 5.3 engine, transmission cooler, but nothing extra on the suspension. The trailer has a Reese WD, anti-sway hitch. Do you feel that will be sufficient for our 1,500 mile trip? My only other option is for us to take two vehicles and my wife would follow me in the car. We'd like to avoid using two vehicles, but want to make sure the suburban will do the job. Thanks!
  • At 7200# your hitch weight would be 930# so that's under the hitch rating. Looks like your payload is around 1500# but I would weigh your vehicle loaded with gas, people and supplies and subtract that from its GVWR to see how close you are to that number and go from there! Good luck!
  • This is somewhat off topic but I haven't been able to find info anywhere else. Do you have to extend the slide in order to load/unload gear from your TT? Also, how much walking room is there from the master Bedroom to the bathroom when the sofa couch is in use as a bed? Thank you and I hope you're enjoying your Bullet. If everything goes well, we'll be proud Bullet owners ourselves in a few months. Cheers!
  • Just a note, if you can find one I have observed that there's a lot of 2500/250 series vans out there that have a good tow weight rating and will offer you a lot of interior room. From what I have seen, just looking myself, the 2500 series vans all have a higher rating than the 1500 Suburbans.
  • Tow rating easy.
    Combined weights easy
    Hitch rating easy.
    Max cargo capacity is vehicle dependent, not so easy.
    My F-150 can pull 9500 lbs. It can only carry 1411 lbs. Adults, dog and tongue weight use up most of that.
    What is the suburban's max cargo capacity?
  • If you are used to how the 6.2L tows, the 5.3L may be frustrating. IF you do not have the Suburban already, then you may want to seek out a Yukon XL Denali, or even better a 2500 Suburban/Yuk XL.
  • I towed my Keystone Bullet Premier with a 2007 Suburban 5.3. I did put airbags in the rear which helped. The 5.3 liter struggled. It towed but never felt comfortable.
    Two years ago I switched to 2011 Yukon XL Denali with the 6.2. Night and day towing. Love it.
    Pretty close to weights for the travel trailers. So yes you will be able but it will struggle.
    Just my 2 cents.
