Ah...the good old BAD GM battery side post issue...if GM still has side post batteries in your year Suburban...
There is a one time use, lead, crush washer in the stack of stuff on the positive side post
One time usage, as once it is used and crushes to provide the proper contact pressure...it will "NO LONGER" provide proper contact pressure if reused.
Not many believed that on my old Suburban/SUV forum, but those that actually cut apart their positive lead lug end plastic...they found that crush washer
What happens is that the next time the positive post bolt is tightened...there is NOT enough lead washer thickness left to provide proper contact pressure...so everyone...me include till discovered this...cranked the bolt down a bit harder...
what then happens is that the bolt pokes into the battery case and cracks it. Just a bit, or lots if cranked hard enough
That then setups this failure mode:
- Acid leaks out ever so slightly and slowly
- That then corrodes the contact stack of lugs
- That then has the acid wick down the Positive Cable
- That some times corrodes the starter electrical post and sometimes the solenoid
- That then has the positive connection at the battery become intermittent
- That then cause all kinds of gremlins that is almost impossible to diagnosis
- That then load dumps the alternator numerous times to kill the alternator diodes
One of the question I ask is how many times have you had your alternator go bad...also if you have ever jump started another vehicle with your vehicle's engine still running...these two things kills many alternators
This become a vicious cycle chasing ever failing components seemingly associated
Solution is to either switch to top terminals, but few have the room between the hood metal and positive post
Bests solution is to toss that lead washer and replace the custom GM bolt with either a regular bolt of the right thread and LENGTH. That also is long enough to poke out to have a second jam nut between the bolt hex head and the stack of cable lugs. Gotta also have a brass/copper washer interface with the lead connection land on the battery. As that landing sits below the plastic case area
You can keep that stupid lead crush washer with the below image solutions...but was so PO'd that tossing it was the best for my mood at that time...
Not able to take a picture of mine, but found these pictures of what you can buy. I'll take a picture later and post back, but for now here are the pics found on line...such a common gremlin...
