Boharris
Jul 12, 2013Explorer
Suburban furnace won't start
I have just purchased a 1998 Thor California Tahoe TT. All works but I can't the get furnace fan to start. A/C works as it should with the Duo Therm T-stat. I have pulled out the furnace and have power directly to the fan but no power to the red wire directly across on the 4 pole relay on the motor (not sure if i should). I can jump the +12v and the Heat on the t-stat and the fan will run for about 30 seconds or so then stop. What do i need to check next or change?
