Old-Biscuit
Oct 31, 2013Explorer III
Flame should be high enough to engulf the electrode.......otherwise the milivolt signal can not be generated to 'prove the flame'
If you have cleaned the burner and the main orifice.....then sounds like gas pressure is the problem.
Did you try disconnecting gas line at furnace and blowing it out?
11" WC WITH stove top burners lite, on high and maybe even water heater on
14" is MAX
14" is MAX
44,066 PostsLatest Activity: Jul 25, 2018
