fairfaxjim
Nov 29, 2013Explorer
We Cant Wait wrote:
Had the same issue and the problem was with the pilot ASM itself, and was replaced under warranty. The pilot will stay on all the time till the stove burned is lit and then as the burner warms up the oven the pilot will start going on and off like it was starving for fuel it also made a little popping sound. Then when the burner reached temp and went off the pilot would stay off till the oven cooled and the pilot was relit. Pilot ASM replaced under warranty.
I had this same problem with my Atwood/Wedgewood oven (OP has Suburban). They had a run of pilot burners that had the wrong size air mixing hole drilled in them. I tried to buy a new one - stove was out of warranty - but couldn't find one in stock. A call to Atwood customer service resulted in a new one mailed to me free.
I had to remove the fixed shelf that the burner/pilot assembly is mounted under to do the replacement. Problem solved now, oven works great!
