wmoses
Nov 29, 2013Explorer
fairfaxjim wrote:
I had this same problem with my Atwood/Wedgewood oven (OP has Suburban). They had a run of pilot burners that had the wrong size air mixing hole drilled in them.
I had to remove the fixed shelf that the burner/pilot assembly is mounted under to do the replacement. Problem solved now, oven works great!
Jim - when you say it was the wrong size, I take it that the hole on your original burner was too small ...?
I know it might be hard to tell from a photo but could you comment on the size of the hole in my photo compared with your original burner? Looks like I can make the hold smaller by adjusting the nut next to it but if it too small then nothing can be done other than replace it.
