mdriver1's avatar
mdriver1
Suburban SF30 Furnace
Hi,
To start Merry Christmas to rv.net members. First time poster here.
Suburban SF30 furnace in a 2006 Gulfstream Innsbruck (bought used)
Question:
Has anyone seen the air wheel (#350184) on the blower motor get warped? It's plastic and appears to be in decent shape (not broken or missing vanes, tight on shaft, etc.) but is rubbing the housing it sits in and not true while spinning (very visible warping), therefore making a terrible noise. Took motor out, air wheel and squirrel cage off and motor seems quiet. Shaft is a little tight by hand turning but not sure how these motors are supposed to "feel" by hand turning. In a little bind as it's somewhat cold here in TN but this week is quite warm. A good time to fix this. I see the motor does come apart and am wondering if it's worth the time to replace bearings or buy a motor? My experience with other motors (lathes, etc.) usually points to bearings. Very rare to see a shaft warped.
Sorry for the bombardment of questions but don't wish to spend more money than necessary to get back to heat when the cold does come back.
Thanks,
Mark Driver
Knoxville, TN
  • The fans will wobble a little. Best you can do is adjust the fan blade on the shaft so it clears.
    The fan motor will have some restriction in turning by hand.
    Move the bare shaft around side to side. If there is no slop in the bearings or bushings put it back in the furnace. I would write down the exact model number for future reference.
  • I would be willing to bet that all your noise and vibration is the plastic blower wheel and the motor is fine. If there's no visible warping on the shaft and the motor runs quiet just purchase a new blower wheel. Since it's plastic I would double check the new one before assembling everything.
    What a crock that they make everything so cheap on an RV. I think the industries goal on RVs is to make it good enough to last the warranty and after that they're assured to make extra income on parts and repairs. What can I say though we all keep buying em ! LOL
