Angus_NB
Sep 06, 2016Explorer
Suburban SW6DE slow ignition
I have a new Suburban SW6DE water heater.
I use it on 12 volt only.
When I turn on the switch the water heater does light but doesn't seem to light as fast as it should.
There is a small explosion every time. As if propane is building up before it lights.
I've had a licensed "propane guy" check the gas flow, he says it's correct.
Voltage is good, usually above 11v.
What could be causing this? Misaligned electrode or too much gap maybe?
Thanks
Thanks
