RoadXYZ's avatar
RoadXYZ
Explorer II
Sep 05, 2014
Suburban Tow Vehicle - mud flaps width
Not sure really where to post this question .. but was wondering what people put on the rear of their tow vehicle to keep the front of their travel trailer clean ...
Have seen motorhomes with full length across the rear mud flaps .. and have seen trucks with them .. does anyone know if this is the answer to keeping the front of the travel trailer clean, or if there is another way.
Just getting tired of all the mud, etc. picked up on the roads in our journeys. Any helps would be appreciated.
  • I'm running road tammers which you can adjust quite a bit, very happy with them, seems to keep most of the road muck off the trailer. Now those pesky bugs on the other hand!
  • On my rig now, I don't use anything but wheel well flaps. I found that the only thing the wide flaps did for me was minimize rock damage.
    I come from the old school, so I always see these things as a way to keep my money in my pocket, rather than giving it to people I don't know.
    I decided that my new set up I would concentrate on the rock damage vs the road grime. Road grime is a lot easier to remove than rock chips. In my case I am dealing with a fiberglass nose cone, so I sprayed the lower portion with Rocker Guard, if it needs, I can just add another coat. If you have checker plate on the front, you could probably just let it happen, then down the road you could replace the checker plate at less than the cost of the fancy flaps.
    The cost of a can of Rocker Guard in Canada, $12.00, the satisfaction of keeping my money, well you know.
  • Check out DuraFlaps, They are great quality, made in the USA and can be had in different lengths and widths.
  • I have mud flaps attached to the truck in the wheel well. I also have a full width mud flap that attaches around the hitch. Mud still gets past everything.
    Photo of my Springdale and my old truck a few years ago. I had mud flaps and the full flap across the back of the truck. Sometimes, it's just not enough:
  • I have mud flaps on my truck but still get mud once in awhile on the front of the 5th wheel. Not enough that I would change anything though.
