davehultin's avatar
davehultin
Explorer III
Aug 28, 2016
Suburban: What are my limits?
My wife and I are starting to get the bug to upgrade our trailer. I have a feeling it's going to turn into one of those vicious circles: Upgrading a trailer means getting a beefier tow vehicle. And if we have a beefier tow vehicle, why not get a bigger trailer?!?
Anyways, I'd like to NOT start that circle. I'd like to find something that our current 2009 Suburban (1500 with a 5.3 engine) can handle. Right now we're pulling a trailer with a GVWR of 6350 pounds, and that travels quite nicely.
I'm not quite sure how to interpret the ratings in the burb's manual:
If I'm reading it right the burb (long wheel base) should only pull 5400 pounds, but it does nicely with what we've got, so I think I have the HD cooling package. At least I think that's what that mysterious small, square extra radiator is, right? If so, that puts my capacity in the 7900 pound range ... correct?
So, I guess the big questions are: how do I know for sure if I have the HD cooling package? And how much can (should?) I tow with this vehicle?
Thanks,
Dave
  • you'll run out of payload capacity WAY before you get close to towing capacity, ESPECIALLY with a SUV.
    what does the Burb's driver's door yellow sticker say is the payload capacity?
    also, you need to figure out what rear end ratio it has.
  • SoCalDesertRider wrote:
    You need to know the axle ratio.
    If you have 3.42, that is not a towing ratio. If you have 3.73, that is a beginning towing ratio. If you have 4.10, that is a towing ratio.
    3.73 is only on the 2500 models...
  • You need to know the axle ratio.
    Thanks,
    Dave
    Don't fall into the trap, you'll end up in a NEWMAR KING AIRE :)
  • You are at your limits. 7900 isn't going to be realistic with a travel trailer..
