carringb
Oct 21, 2013Explorer
The 6.0 is still a small block. It makes its power up high.
Easy solution to the gear-hunting problem: Manually select a lower gear. The 5.4L will pull that weight no problem. High RPMs won't hurt a thing.
The 6.0 is no big block, so if you are expecting it to pull and never downshift, you will be disappointed.
