TurnThePage
Jul 31, 2017Explorer
theoldwizard1 wrote:My response was simply based on the OP's original post. IF they are only worried about a couple nights of 25 degrees, they don't need a true 4 season trailer.TurnThePage wrote:
Almost any trailer will get you through a couple 25 degree nights.
Find a small, "true 4 season" TT, one that you can use in MN in January, is going to be next to impossible.
You need at least 2" of foam insulation not only in the walls, but also the floors. The ceiling should have 4". Either that, or get a big furnace.
I guess if you are not paying the electric bill a couple of small electric space heaters will work. You ill have to wire the TT for 30A service with plugs on different breakers.
A heated mattress pad is more comfortable than an electric blanket. You will need one when the temps drop into 20s.
However, since the details have become more clear; If I had physical limitations, few belongings, and wanted to live in a small travel trailer, I would likely choose the larger Oliver or a Bigfoot model. Both of those should require about the least maintenance, and endure the widest extremes. A smaller Lance might cut it too.
Of course I don't cook very much, and could get by easily with just the two burners.
