valhalla360 wrote:
Cummins12V98 wrote:
Why not add airbags and set to have the truck run level. Bilstien's are another good add along with proper tire pressure based on load.
They are a 3-4 times the upfront cost and they require maintenance and adjustment.
And before you say it...Installed incorrectly, they won't last long either.
A basic set of 5klb bags is around 10% more than a set of sumos. Giver take.
I suppose they do require adjustment. IE adding or removing air.
But you’re comparing 2 different products that perform a similar function.
I never have had airbag maintenance on any of my to do lists….Had one fail at 15+ years old. But I’ve never used sumos or Timbrens for 15 years to compare whether they last longer.
Bottom line, OP got too soft of Sumos, or relied on them too heavily or improper fit/install. Or combination thereof.
