- SkibaneExplorer IIThere have been reports of the plastic losing its resiliency in a few years.
- GdetrailerExplorer IIIMEH, $500 for polyurethane pucks that restrict your trailers suspension movements?
Calling them "springs" is an oxymoron.
You can remove the leaf springs and bolt the axles directly to the frame, saves the $500 and effectively does the same thing.
I see a bent/cracked/broken frame in your future.
If you are having control issues, adding some shocks to provide some controlled damping would be a better choice and half the cost. - LwiddisNavigatorExcellent video quality and narration.
- Grit_dogTrailblazerYour springs sacked out, or you got the TH loaded to the max?
Odd, as one thing that typically isn’t lacking on toyhaulers is spring capacity. - 2112Explorer IIDid it solve your problem?
44,070 PostsLatest Activity: Aug 07, 2026
