Grit_dog
May 12, 2018Navigator III
They will reduce sway some by effectively stiffening the suspension up.
But if your ride height is already pretty high with the stable load combo, they won’t do a lot. If you have a fair amount of squat they’ll help more, but not like a sway bar that works one side against the other.
Occasional use, fine, but if I had a primary camper hauler as you do, set it up right and put a sway bar on it. Idk how the exhaust conflicts with it, but it has to be a fairly easy fix. Couple hours at a muffler shop with a whiz wheel and buzz box!
