For the fun of it, I pulled up a gear ratio to speed calculator:
With the ford 2.7turbo, 3.73 rear end, 4.86 reverse gear and 32" diameter tires...30mph is 5710rpm. Redline is listed as 5800rpm...Assuming you aren't running around all day in reverse, this shouldn't harm the engine.
If you drop back to 25mph, it's a much more sedate 4750rpm.
So even with the really deep granny reverse gear, you can tow (push?) at 30mph on occasion (at least theoretically).
I'm still trying to figure out what scenario this makes any sense.
- If you have any significant room that the slightest mistake doesn't put you into the ditch/wall, it's easier to turn the rig around.
- If its a tight narrow twisty road where you can't turn around, you just increase the difficulty level 10 fold getting up to 30mph (regardless of gear ratio)
Update: Looks like if you have the diesel, you are limited to around 20mph in reverse as the engine is governed at 3700rpm.
