Installed the HD Super springs last night. These things are stout. Raised my rear 1 1/2"(measured from increased distance of bottom of bumpstop to perch it hits when it bottoms out)BUT visually from outside measurements the rear is only 3/4" higher so it does not look high in the back. Conclusion is my rear end was sagging 3/4" unloaded to begin with so these super springs bring my ride height up to only 3/4" over OEM but 1 1/2" over where I was pre install (assuming front and rear are same ride height) but now when I load the TT and throw on the golf cart I should ride level.
