~DJ~ wrote:
Kayteg1 wrote:
I think the bands allow for truss movement.
I am researching the stinger hitch and I think for better strength it suppose to be welded, although it will make installation harder.
It may make it impossible. :)
If everything is done correctly, 2 parallels trusses should go into parallel receivers easy, but any bend will require sledge hammer for removal.
The point is that with clamps allowing movements, you do have 2 single truss working together and as I observe on the road, they do flex.
When you weld them few inches at the end, you are making tall I-beam that more than double the strength/stiffness.
Now the stiffness will transfer on the hitch, so all the movements from trailer will go on the truck hitch frame without cushion, what will put the frame to the test.
