rbpru wrote:
I still have yet to have anyone tell me how they know their surge protector worked or is still working.
I know some of the high dollar units will tell you, about high and low voltage but do they kick out when a surge occurs or what?
Whether a simple surge protector or "high dollar" EMS any surge exceeding the rating of the unit will destroy the MOVs (Metal Oxide Varistors) used to direct excessive current flow to ground. Progressive units will indicate if surge failure has occurred and no voltage will be outputted. Clearly, if the unit still is outputting correct voltage then it's still working. :R If the unit
has failed all it takes is a call to Progressive to request repair under the unit's lifetime warranty - in the case of a hard wire unit which is field serviceable Progressive will mail the parts to you.
This is an inside view of my own Progressive EMS-HW30C ...
It contains two circuit boards - at the top left is the surge protection circuit board containing MOVs ... in any case where these may have sustained a damaging hit it's simply a matter of removing the damaged board and replacing it with another that Progressive will mail to me at no cost under the lifetime warranty.
At the top right is the EMS circuit board that monitors for any line errors and should any be detected causes the contactor in the centre of the pic to open and thereby disconnect power to it's output and therefore the trailer. This circuit board also is field replaceable, again at no cost under the Progressive lifetime warranty.
I've not opened a Progressive portable EMS-PT30C as it's sealed and considered by the manufacturer to not be field serviceable so if damaged it must be returned to Progressive for repair. That said, it functions electrically the same as the hard wire version so there's little reason for the interior parts to be any different.
A simple surge protector such as that mentioned by the OP contains only a surge protection circuit board with MOVs - no EMS circuit detection, no contactor. The reason an EMS costs so much more should therefore be obvious. ;)
