rickjo
Aug 05, 2015Explorer
Christl wrote:
Hi rickjo, thanks for response. My truck is a dually. I am trying to not make same mistake again and become overloaded while upgrading to this larger TC (don't want to spend thousands on mod's.). Owner indicated they are only using torque lift stable loads to engage springs earlier and I wanted unbiased opinion. Can you provide amount of air you are putting in the air bags and explain how the air bags improve drivability in addition to the larger bump stops or are you mainly using the air bags to level load right to left - thanks
I run my airbags at 90# with the camper on. For those times when I am using the pickup as a "truck", I lower to 5# and I do get a SLIGHTLY gentler ride. An empty dually is never smooth. I try to think of the airbags as keeping the rear end at a proper height, whatever that is... Springs and shocks provide the rest of the stability.
Rick
44,071 PostsLatest Activity: Aug 16, 2026
