Christl
Aug 11, 2015Explorer
Hi Everyone: Thanks for your help on this topic. I found out from Torklift they do not provide Part #'s for Lower Quick Release Stable Loads for 2015 GMC 3500HD because there is very little space between the lower spring and the rest of the spring pack.
(Good Afternoon Christl,
Thank you for your inquiry and support. I appreciate you for allowing me the opportunity to assist you. The reason why we do not have lower overload Stableloads confirmed for that truck is because of the lack of gap between the leaf spring and the bottom of the spring pack. Most of the trucks we tested on had little to no gap and could maybe fit 1 plate in there. A7202 has been a better fitment due to the amount of gap between the upper spring and the bump stop. I would recommend looking into the upper A7202’s.)
I will be going with Upper Stable Loads, Hellwig Big Wig Sway Bar. and see how stock shocks preform first time and go from there based on everyone's input.
One quick question - I have Rancho 9000 shocks on my GMC 1500. Are they different then the Rancho 9000 shocks for a 2015 GMC 3500HD? cheers Christl
