GaryWT
Mar 05, 2014Explorer
Not sure why you are blaming the factor, all Premiers are set up the same way. The factor builds to the engineering specs and for the Premier it is built as is, it is not like they pick and choose what trailer will have what axles and what goes on top or on the bottom. I guess they use to use smaller axles but they started to bend so they changed what they used. As I said before I hope it works out for you.
