dodge_guy
Mar 05, 2014Explorer II
GaryWT wrote:
Not sure why you are blaming the factor, all Premiers are set up the same way. The factor builds to the engineering specs and for the Premier it is built as is, it is not like they pick and choose what trailer will have what axles and what goes on top or on the bottom. I guess they use to use smaller axles but they started to bend so they changed what they used. As I said before I hope it works out for you.
Engineering specs? HA HA! as you even stated they put the wrong axles under them and when they failed went to a larger one.
To the OP. if you have the room and the clearance I would lower it. I had an Award and it sat very low! never had an issue bottoming out on anything. personally I would rather have it lower as it does make an improvement in stability (center of gravity) and fuel mileage.
Go for it!
