Payload and GVWR ratings may be misleading. The manufacturer can understate them for a variety of reasons (meeting federal / state regulations, competition, stratification between lines, warranty claims, etc.). For instance; I have a 2000 F350 and a 2014 Lance 1191. I weighed it with and without the camper on DOT scales at a Love's station and I'm about 1300 lb's over my GVWR fully loaded with passengers. On the other hand, I'm under on my axle ratings by a few hundred pounds.
What are they trying to avoid by underestimating the ratings? Commercial Vehicle Registration Act of 2001 (F450). Federal Heavy Vehicle Use Tax (F450). I live in Arizona and they have a tax that the F450 falls under as well.
You would be better off in a heavier truck, but I understand sometimes it's not in the current cards. Since you don't have a lot of options at this point, I would get it weighed at a truck gas station like a Loves with the camper on. It costs $10. The will weigh the front and the rear at the same time. Find out what your GAWR (Gross Axle Weight Rating) is for the front and rear. It's typically on a sticker in your door jamb. Don't go over those weights. If you are over GAWR, you're done from a safety standpoint. If you're under, and I suspect you are, then look at your tire rating, I suspect you'll be way over. A good LT E rated tire will have a payload of ~ 3500 lbs which will work. The stiff sidewalls really help.
After that, visit a spring shop and get some extra leaf springs on the rear to help with the sag, plus torklift stableload bump stops. The spring guys will be able to help you with that. I'd avoid timbrens, they will impact your unloaded ride. HD shocks like bilstein or Rancho shocks next. Evaluate the ride and if you need more, then swaybars (back 1st). From the posts I've read, "every 1/8 inch increase in diameter of the swaybar produces a 30% increase in strength". The two main swaybar candidates are Roadmaster and Helwig BigWig. Choose whichever has a bigger diameter bar. I have Roadmaster on my rear and Helwig on my front. Airbags if you are still getting sag.
In summary, your camper says it will fit on a 1/2 ton. Weigh your camper and truck and see where you are on GAWR. If you're under GAWR and your tire weight rating then start your suspension mods. GAWR and tire ratings are hard numbers that I won't exceed.
