mike326ExplorerJul 28, 2014Suspension modsI could use some wise advice. F150 SRW 4WD w/ trailer package. Mated with NorthStar Adventurer 8.5. Despite assurances from both car & TC dealers - fair amount of sag & sway. While many may say I ...Show More
AH64IDExplorerJul 29, 2014Need to know a few things before making a recommendation. What is your RAWR and GVWR? What is your scaled empty weight?What rear axle do you have? Post a photo if unsure. There is generally some wiggle room, when looking at trucks... Not much on a 1/2 ton as a 3/4 ton, but you might be able to carefully pull it off. If you where sold something you couldn't do with the equipment you presented I would demand a full buy back, then get an appropriate truck.
Related ContentNeed Suspension ModsSuspension mods?Next suspension modSuspension mods to lower height of TT2012 F 350 suspension mods needed?
