Lynnmor wrote:
Terryallan wrote:
Lynnmor wrote:
Then there are all those popular, expensive brands that can't be adjusted for slippery conditions.
You are simply not to use them in slippery conditions. your TT should not sway with out one. They are only for emergency situations.
Then all those folks with the popular, expensive brands need to get off the road at the first sign of inclement weather? Or do they need to remove all the weight distribution and then continue on?
No not WDH. Just the swaybar. The honest truth is. Your travel Trailer should NOT sway in normal driving WITH OUT a sway bar. If it does. You have serious problems. I have towed with out the sway bar. I have no sway.
