ssthrd wrote:
TurnThePage wrote:
Lynnmor wrote:
TurnThePage wrote:
Me thinks that the mentioned issue/condition is strictly for the add-on friction sway bars and has nothing to do with all those popular and expensive hitches with anti-sway built in.
The condition is that sway mechanisms keep the truck and trailer in line. When the tire traction is not great enough to overcome the resistance of the sway mechanism, skidding when turning will result. It does not matter what brand, style or price point is involved.
Strictly speaking, I can't argue. I just don't think it's a thing with those "expensive" hitches, while there are various warnings when using the add-on anti-sway bar.
This is confusing-at least in my mind.....
I have an Equal-I-zer with 4 point sway control which uses friction at 4 points to address any sway issues. I do not understand how the effect of the systems are different. In other words, how can one system using friction be safe in slippery conditions, and another not? Since they both work to keep the trailer and the truck in line using the same principle, how can they be different?
An email from Equal-I-zer tells me that it is not an issue, but they gave no explanation about how their system works in any conditions, while others are not safe and should be removed.
Physics was always one of my best subjects, but I can't get my head around this one. Any engineers out there that can shed some light on this for me?
My guess is that while the Equalizer resists slipping, it will eventually slip, likely well before the truck is to lose traction. It's basically the same reason you have to take off a friction sway bar but don't have to remove the Equalizer when backing into a spot, you'll get the classic pop and groan but the bar will slip on the plate.
