Terryallan's avatar
Terryallan
Explorer II
Sep 26, 2020
sway bar instructions
Have any of you read as I have the sway bar instructions? Especially the part about NOT using the sway bar in the rain? HINT. It really means what it says. It CAN cause the TV to go straight in a turn. Want to know how I know????
Thursday as we hooked up to come home it was raining, and I thought about the instructions, but put it on any way. ( my TT doesn't sway with out the bar). So I put it on anyway. and had O problems until I went to turn into a driveway. Yes I slowed way down, But as I turned, the front tires started sliding. The truck did NOT want to turn. But it finally caught and I went into the driveway. Scared me some as we were still in the mountains and there was a pretty good drop beside the driveway.
Anyway. moral of the story. There is just barley a chance the manufacturers know what they are talking about when they write the instructions. And it is required that your TT be setup correctly and not sway, even with out the sway bar.
    Glad you are OK and everything ended well.
    I bolded the most important part of your post.
    It is why a take all the safety police on this forum with a grain of salt who insist one MUST always use WD and anti sway devices in all conditions and all combinations.. Those items are nothing more than a bandaid slapped on top of a very bad TV/trailer combo (way to heavy or too long of a trailer) and or not properly distributed weight on the trailer (IE not enough tongue weight).
    WD and even friction anti sway devices were designed to help folks tow larger combinations than they would be able to with a lesser tow vehicle.
    Your rig SHOULD and MUST tow CORRECTLY in any and all conditions BEFORE you ever slap on those feel good bandaids.
    And YES, that means you need to select a trailer weight well below the max "ratings" of the TV.. It is why one should pay attention and use to the GVWR of the trailer instead of the supposed dry weights.
    YES, that means you may end up with a much shorter and smaller trailer with 3K of cargo weight that you will never need.. So be it, to be much SAFER to start with without the aid of slapped on bandaids is a much better way to tow.
    I didn't know the difference until the day I bought a much heavier 3/4 ton to replace a light weight heavy half.. Much better towing, feels confidant in all weather conditions and the truck is in command instead of the trailer.. And I do not need those devices to be able to tow for my combinations.
    Yes, my comments will raise the hackles of good intentioned towing/weight police and I don't care, it really needs to be said.
  • Then there are all those popular, expensive brands that can't be adjusted for slippery conditions.
