Just returned from a great week of summer camping in norther Michigan. Hot weather so good thing a/c worked and had a great lake. My question relates to noise I hear from the hitch area. I assu...
The sway bar will moan and groan some. That is normal.
It is recommended to remove the slider bar from the sway bar and brush it with a wire brush. (wear a mask).
Your on/off bar should be all the way on but not so tight that you can't tighten it by hand. I bottom mine out and then make sure that the handle is pointed towards the travel trailer.
