BarneyS
Aug 10, 2013Nomad
As mentioned above, the Curt is just a WD hitch with no sway control unless you add on a friction sway control bar or two (two recommended with that big of a trailer). The Equal-i-zer and Reese Dual Cam hitches mentioned combine both Weight Distribution (WD) with sway control into one hitch. There are also other hitches that combine both functions such as the Husky Centerline, Andersen, Blue Ox Sway Pro and some others.
In my opinion, you absolutely should use some kind of sway control with that size of a trailer.
Barney
Barney
44,056 PostsLatest Activity: Jan 12, 2020
