SoundGuy
Jun 26, 2016Explorer
bleaux skies wrote:
The trailer is a 2017 1706fb micro minnie.
Your 2017 Winnebago Micro Minnie 1706fb's factory dry weight is 2980 lbs so that would suggest it's a single axle, which likewise sugggests that a UVW of 3180 lbs that you detailed in your original post is most likely this particular model's actual stickered dry weight - correct? If so, I'd expect you'd probably be running around 4000 lbs loaded and ready to camp so at 14% that would be ~ 560 lbs gross tongue weight, which is well within the ratings for 600 lb WD spring bars.
