We just purchased a 2020 Freedom Express Ultralite trailer--weight is 4800 lbs. We are towing this with a 2019 Ford F-150 with the heavy duty towing package with sway control. We have the weight dis...
Based on the Freedom Express manufacturer's website the 4,800 lbs will be unloaded weight and gross will be 7,000 or more. You'll be close enough to the max towing capability of your F-150 to want sway control in the hitch. Which hitch do you have? If no sway control in it, do get the anti-sway bar. You will have about 1,000 lbs on the hitch of the truck.
