I've towed with and w/o sway and it's mainly just a peace of mind thing having it. By far the most common time to get sway is with something pushing at your back. This is most often the gust of window sucking behind a big rig if he is passing you. When I towed w/o the sway control I'd have to constantly be watching in my mirror. Now that I have it I don't have to watch as closely.
As for the OP's question, I don't think adding a second sway control will be life changing. There's only so much that hardware can do for you. A good exercise is to mentally plan for how you'd react in a bad sway situation. Most people's first instinct is to hammer the brakes which, unfortunately is the absolute worst thing you can do in most cases. The sway is happening due to too much slack at the TV to TT connection. So, to stiffen it up you can either accelerate (tough to do in a crisis) or lay off the TV brake but hit the trailer brake. This stiffens the connection and gives you the best chance at regaining control.
Think it through in your mind and be ready if/when the time comes.
