Judithgap's avatar
Judithgap
Sway Bars and Air Bags
First please forgive me as I am still researching the purchase of my first truck camper. I plan to install both the front and rear Hellwig sway bars on my 2014 F350 4x4 short bed truck and want to know if it would be advantageous to install rear air bags also.
Would be any problems with having both?
Thank you for any feedback.
  • Bigfootchevy wrote:
    I also thought Fords came with sway bars. Why do you think this truck would need air bags? The only thing I would add to your SRW Ford truck is torklift stableloads.
    You need the camper package to get the sway bar on an SRW, sway bar is standard on the DRW.
  • gpascazio wrote:
    I would wait to make mods until I have a Truck Camper on the truck. If you decide on a smaller and lighter camper you may not need either. IN other wards don't try to fix what's not broken.
    X2
  • I would wait to make mods until I have a Truck Camper on the truck. If you decide on a smaller and lighter camper you may not need either. IN other wards don't try to fix what's not broken.
  • okan-star wrote:
    Sway bars:)
    Air bags:(
    That is correct. The Hellwigs are much more larger in diameter and stronger.
    I sure appreciate the feedback I get from you guys and cant wait until I am in a position to buy the camper and get out on the road.
    So many places to see.
  • Just try the Stable Loads first, remember the TC's Centre of Gravity needs to be forward of the Axel.
    Remember the Airbags are only to increase ride height back to correct/original ride height.
  • Hellwig sway bars are twice what Ford puts on and make a marked improvement.
  • I also thought Fords came with sway bars. Why do you think this truck would need air bags? The only thing I would add to your SRW Ford truck is torklift stableloads.
  • They are two different systems. The sway bars are to keep roll down and keep the tires from lifting off the roadway. The AB's are used to level the rig, from side to side or rear to front.
    Get the rig and add as you need the stuff.
    Fords usually come with sway bars. AB's aren't always needed.
