Silvergray49's avatar
Silvergray49
sway bars
Sold my TC and am looking at a 19ft TT. I have a 2009 GMC 2500 HD to tow with. I am not as strong as I used to be and would need some easy to use sway bars. Any suggestions.
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    2Rad4U wrote:
    old guy wrote:
    electric tongue jack. just use the jack to raise the TT once it's hooked to the tow truck and then the bars will go on very easy, then just lower the jack and you are set to go
    I'll second this suggestion
    and I'll third the suggestion. For a 19ft trailer you probably won't need much force to transfer the needed weight and a electric tongue jack should make it quite easy to put the spring bars on.
    I have a 14ft cargo sport trailer, about 6K lbs with 600lb bars. with the electric jack I could jack it up enough to attach the bars w/o using the "cheater" bar. Usually don't jack it that much but I could.
  • Ya probably do not need sway bars for a trailer that small , I pull a 21 foot with a Ram 2500 , no sway or sway bars .
  • 2Rad4U's avatar
    2Rad4U
    Explorer III
  • Attaching bars to the hitch is easier on some. Mine bars go “up and into.” The “down and into” are easier.
  • electric tongue jack. just use the jack to raise the TT once it's hooked to the tow truck and then the bars will go on very easy, then just lower the jack and you are set to go
