kbravo1974 wrote:
Thanks all. First the tires on the truck are new so air pressures are good. I agree that the dealer should have probably sold me the next size up on the WDH bars given the tongue weight published is over 1000 lbs. I think that my heights are okay, but I will double check this.
I will keep researching this issue. Thanks for your suggestions.
Pay close attention to the angle of the ball and how/when to adjust it in that article, too.
Your tire pressure on TT should be at Max Cold pressure on the sidewall. Also, take a look at those tires for condition, WEIGHT RATING, and unusual wear.
Since you have a borderline capacity WDH from the dealer, it's possible your trailer tires are also near (over?) their max. When near the max, they flex quite a bit more compared to ones that are 20% or so below max capacity.
Things to consider.
