gates59 wrote:
I have a quick question on a lower weight distribution bars. Mine are somewhere around 150 lbs less than the weight on my tongue. Will larger bars stop the bouncing front to back my trailer makes on bumps.
They should help by taking more weight off the rear axle of your truck.
But if you are over the truck's GVWR or rear GAWR, maybe a bigger truck or lighter trailer???
If not, perhaps you should look into stiffening your truck's rear suspension. There are many products available, extra leafs, super-springs, timbrens, air bags, roadmaster active suspension.
LT-metric tires and HD shocks might help as well.
