hoping4fun66's avatar
hoping4fun66
Sway Control Info
While I am not new to towing, I have towed 5th Wheels for many years, I am new to towing a TT. Wife and I are looking to get a smaller TT, something around 21 to 22 feet, with a weight of about 3,500 dry weight.
Weights are not a concern at all, my tow vehicle is a RAM 3500 dually. So my question is, what concerns do I have with sway? I assume I do not need to worry about a WDH? There is no way I can overload my truck with this camper. But I also assume that I still need to worry about sway?
I just do not want a salesman talking me into a expensive hitch setup if I do not need one.
Scott
  • I just got my travel trailer, so only have a few hundred miles towing it. But it is about 4k lbs and I don't seem to need any away control. I have a 1 ton srw Cummins. I had no problems at 65-70 even around semi trucks. Every once in a while I thought I might have seen the smallest sways in rear view mirror but not enough to even feel in the truck. Add tongue weight and hammer down.
  • Ivylog's avatar
    Ivylog
    Explorer III
    Lack of enough tongue weight is what causes sway with a TT. Put heavy things in the front of the TT and go camping. With your truck you cannot have too much tongue weight.
  • I agree with everyone so far. Load the TT correctly balanced.
    Don't confuse sway with the push n pull of overtaking trucks (thats normal)
    Look at all the enclosed 30-35 ft (5000 lb) ATV/snowmobile trailers being towed direct to the ball without a WD hitch or sway control. Year after year and many thousands of miles.
    We just returned back home from a (steady 20mph with 30mph wind-gusts) 500 mile tow using a 3000 lb loaded enclosed v-nose trailer direct to the ball using a 1500 truck with the truck bed also loaded up. Because the unloaded truck sits rear end high with a max tow package, the combo towed level once i hitched up with a 1.5" squat. No issues at 65-70mph. I had to do a minor headlight adjustment. It towed flawlessly. My DW towed it for 150 miles and she loved it.
    MY TT:
    The transporter who towed my TT half way across the country from the mfg to the dealership towed it direct to the ball using a dual wheel 350 truck. NO WD hitch and no SC.
    Im towing a Jayco 23 RB (27 ft) @6000# wet with approx 800# TW (its 100# more when i bring the bikes on my tongue mounted bike rack, see my profile pic) with a max tow pack silverado 1500 with a Pro series Reese and friction sway bar.
    I've tried the system both ways to see how it tows. So far (about 5k miles) i have not noticed any difference with or without the sway bar.
    I also tried this same 6000# Jayco using my beefed up 2500HD and it it towed perfectly direct to the ball as well as using the WD hitch which i didn't feel any difference in the tow. Wheel well measurements were also in check however, it did squat a tiny bit in the rear but not enough to feel any towing difference or affect steering.
    I did have 'Tork-lift adjustable Stable-loads' on my helper springs which engages the helper spring earlier than normal (without a load).
  • Friction sway control is cheap insurance. Unexpected stuff can happen. There is no downside AFAIK.
  • Tvov's avatar
    Tvov
    Explorer II
    I have a friction sway control bar on my hitch, but it is not critical.
    If you can find a basic weight distribution hitch with friction sway control, you will be fine (even overdoing it) and if you end up towing with something else you will be covered.
  • Since 2013 I've been towing our current Coachmen Freedom Express 192RBS with a 1/2 ton Chevy Avalanche, trailer measures 22' 6" coupler to bumper and typically averages ~ 4600 lbs loaded & ready to camp. I do use a trunnion bar Reese WD system as the Av's rear coil suspension otherwise sags excessively with 600 lbs of gross tongue weight bearing down on the hitch ball but I don't use any friction sway bar as in tens of thousands of miles of towing I've found it unnecessary. With your TV being a 3500 with stiff rear leaf suspension and having a much greater wheelbase than my Av's 130" I'd find it hard to imagine you'd need either WD or sway control towing such a small trailer. :)
  • If a trailer is properly loaded it won't sway. Having said that, I still have a sway control on mine, just a friction sway bar ($100.00±). It's just a belt and suspenders type thing for me. I usually use it but have forgotten a number of times and saw no real difference.
