Community Alumni
Apr 06, 2016I would first verify that the truck is not or close to being overloaded with the trailer attached via a CAT scale. I'm not sure which 28' Puma trailer he has, but the ones I see have a GVWR of 8,000+. That may be a little much.
How to use scales.
Doing this will also help you determine if the hitch is transferring weight correctly. It wouldn't be a bad idea to get a copy of the instructions for your hitch, follow the directions, and verify everything is setup correctly.
How to use scales.
44,029 PostsLatest Activity: Jan 28, 2025
