Community Alumni
Apr 08, 2016Clearly the current system is not work, however if it is setup incorrectly then it will never work correctly. Even a Hensley will fail to control sway properly if it's set it up improperly. The first steps should be to verify the basics and verify that the hitch is setup according to the instructions provided by the manufacturer. Sinking money into a new hitch would be fool hearty if it turns out the problem was just with the setup of the original.
44,029 PostsLatest Activity: Jan 21, 2025
