westend
Nov 05, 2016Explorer
Lynnmor wrote:DutchmenSport wrote:
Sway "yes". About WD? Well... here's an experiment you can try. Get 600 pounds of bagged sand, or gravel, or water softener salt, or even 600 pounds of bricks or blocks.
I can almost assure you though, your headlight beam will be up in the trees!
For weight, here is a better idea: Weight
Yes, those trucks sag quite a bit.
Not at all Lynn! Bridesmaids mean wedding and wedding means money, lots of it.
I have a 20's something Daughter. She is bringing her special Beau over for Thanksgiving and they are going to Boston to his folks over Christmas. I can almost hear the bells ringing. :W
To the OP,
I have an 03 F250 crew cab 4 wd. With 520 lbs of tongue weight I've hauled my trailer without a WDH and it is like one piece of rolling stock. There isn't a big sag situation. Now, I have an e-qual-izer hitch to get the small bit of weight back onto the front axles.
My '03 has the same suspension as a 1 ton of that year. Headlights are not pointed at the sky but are raised.
44,029 PostsLatest Activity: Jan 28, 2025
