Ivylog
Nov 05, 2016Explorer III
A PU will ride/handle better with some weight in the bed. 600 lbs, even on the tailgate will improve the handling. Hook the trailer up and go for a test drive without WD or sway.
The tangent of 2/250 is less than 1 degree so no one is going to flash their high beams at you if you do not use WD...
in the trees :S
in the trees :S
44,029 PostsLatest Activity: Jan 28, 2025
