Sienna65's avatar
Sienna65
Sway control
I purchased a 2014 Jayco Swift SLX 184bh. The RV dealer threw in the the hitch, load levelers and the sway control. The sway control is an Easy Lift.
We have camped about 4 times so far with no problems at all. I went to hook the camper up last weekend and noticed that I couldnt release the pressure off of the sway control bar by using the release lever. I went to the RV dealer and they said the the sway control bar was bent although there were no visible bends. They also said that I must have turned to sharp and caused the bend. I have been very careful not to turn to sharp with the sway control in place.
Is there something that I am doing wrong? Was it on too tight or did I turn to sharp. Or is this just a common problem. Just curious because a new sway control is $85.00 and I dont want to make the same mistake again.
  • Prolly just tightened the lever too tight. I did that with my first one. Tom Johnson replaced it. No questions ask.
  • There should be a second adjustment nut try loosening that. You can get a new one on ebay for $40.00
