Hey guys, I have taken our new single axle RV out a couple times and am struggling with the wind it moves the trailer quite a bit, I have a Weight Distribution hitch , it seems to help just a little, ...
once you have your numbers if you want to add tongue weight don't do it via potable water tank. what happens when that water is used up and is now in the grey/blank tanks at the rear. if you don't want to/cant dump and refill with fresh water before you leave you are now making your problem worse not better.
