ScottG
Mar 02, 2015Nomad
DutchmenSport wrote:
On my first TT we had a Reese system and had the friction sway bar attached. The dealer told us never to back with it on. The reason was because backing could break the small ball on the hitch. Actually, the ball itself would not break, but the hitch itself where the ball is attached would break out the metal. All it took was one time for the bar to bind and that would have been the end of the hitch.
We never backed with it on, never, not even a few feet on a flat straight surface. Never. I always removed it.
There may be other reasons, but this is what the dealer told us. A year go I switched to an Equal-i-zer. I can back up with it on.
The only way that could happen is if the ball on the trailer end was not positioned exactly per the instructions.
Mine was mounted properly and I never had a problem forward or backward.
What ever angle you can turn going forward, you can also turn going backward. There is no difference.
44,068 PostsLatest Activity: Jun 01, 2026
